Water Flow
D Brooks
I have a 2 cycle 8hp Nissan (87 model). It runs great water comes out (strong flow) of the pee hole but no water comes out of the out flow in the back of the motor. It doesn't matter if I am idling or full bore. Only steam comes out of the outflow in the back. I have run the motor for miles and nothing comes out.<br />I am worried that I am gradually damaging the motor. It runs great. I am stumped.
TOHATSU GURU
Re: Water Flow
The majority of the water comes out through the prop hub where you can't see it. But, you should be seeing something....If the engine isn't overheating, don't worry about it.
D Brooks
Re: Water Flow
I see mostly steam. Ever once in awhile I will see a spit of water. Thats it. The motor runs great. The pee whole water flows great.
TOHATSU GURU
Re: Water Flow
Abby-normal, but, the pee indicator takes its whiz after the cooling process is done. If there is no indication of a prostate problem, then you don't need to worry.
