Throttle friction tensioner - Tohatsu 15 or any
Pogo123
I don't have a lot of experience with outboards, but it appears that a throttle friction tensioner would make life a lot more comfortable.<br /><br />My Tohatsu is, thankfully, a very easy, short throw (or twist) throttle, but, even so, an hour or so of holding it gets to be a real chore.<br /><br />From my mototcycle racing days, I remember there were an add-on touring products that clamped to the grip housing, extended to the twist throttle and by which throttle tension could be easily set.<br /><br />Is there such a product for Outboards? ... I sure can't find one ... or ...has anyone else come up with another approach to this?
TOHATSU GURU
Re: Throttle friction tensioner - Tohatsu 15 or any
Your engine should have one on the tiller arm. You access it by rasing the tiller arm and then tightning the knob/screw.
Pogo123
News to me, Elvin .. and to the local dealer.<br /><br />I just took a flashlight and went out to look (it's 10:20PM here), in case I'd missed something ... I had not, but ...<br /><br />There IS a phillips screw in the underside of the grip (about 4" from the end of the grip/tiller arm) that the local dealer told me was to hold the grip to the tiller arm and that it was not a tensioner.<br /><br />I'll try it tomorrow morning. It wouldn't be the first time this dealer has mislead me.<br /><br />Thanks for your time, Elvin ...
TOHATSU GURU
That screw is for the grip...You must have an older model 2-stroke which did not have the tension adjustment feature. What is your model number? I'll look and see if one can be retrofitted for it.
Pogo123
It's an M15D2 351A, Elvin. Sold as a 2001, but produced in 2000.<br /><br />Yes, I took out the screw this morning and all it does is hold the grip onto the tiller. However ...<br />that screw goes through a teflon block and, if lenthened a bit, might just contact the throttle shaft allowing variable amounts of friction. <br /><br />I need to take this apart and see just what's under there. I can (and have) made very thin teflon strips for use as slide bearings or inserts which might be applicable here. I hesitate to increase any pure metal to metal friction as I could get into a "Lock/Unlock" situation.<br /><br />If there is a retrofit or later 15D2 part(s) that could be fitted, that would simplify things immensely.<br /><br />Barring that, I did locate a motorcycle touring throttle tensioner that I can make do the job ... pricey, though. Used to be $12 to $15 ... now near $40.<br /><br />Thanks for your time, Elvin .. I do appreciate it.
Pogo123
Well ... as so often happens, nothing is easy .. but then I guess if it were, everyone would be doing it ...<br /><br />There are no longer reasonably priced motorcycle aftermarket throttle cruise tensioners available. Seems they went away and off the market as they weren't a big seller nor a high profit item. I may find one in someone's "20 year box", but that's now an item for future searching (read: during the winter).<br /><br />There are also no later model tensioners that I could find which could be retro fitted to my engine ( a 2000 Tohatsu 15) ... as I said .. nothing is easy.<br /><br />Looking at this closely, however, I see where I can very likely make an assembly that will squeeze the tiller throttle rod between a teflon pad and an adjustable screw. I've drawn up a couple ideas and will work on it as time permits, but ... in the meantime .. I effected a simple "quick fix" that, while not particularly pretty, seems to work for now.<br /><br />There is a slot in the tiller top at the end nearest the engine through which I can look directly at the tiller throttle rod. My "band-aid" was to feed a nylon cable tie through the slot, from the top, wrap it around the rod and back out through the slot.<br /><br />Tightening it gradually while working the throttle gave "some" tension, but not enough even when as tight as I could pull it by finger (no pliers here). More tension was needed. Rather than pulling the tie tighter, I chose to go for more contact area.<br /><br />Eventually, I wound up with three cable ties installed next to each other which covers about a 3/4 inch length of throttle rod .. 4 ties gave too much and two was still not enough.<br /><br />As another interim step, later today I am going to cut a small rectangular nylon piece (about 1" X 3") with two 1/4" holes 1/2" apart (inside edge to inside edge and mount it against the under side of the tiller with the second or center cable tie. It will merely provide a brace across the open tiller casting for a cable tie from the opposite side.<br /><br />This will give a balanced pull on the throttle rod from opposite directions and prevent distorting the rod from only side loading it one way.<br /><br />Testing this rig was done very cautiously. I had tested it on the trailer many, many times, but still ... on the water I had a pair of cutters right by my hand in case I had to remove the tie(s) quickly.<br /><br />Fortunately, I found no bad habits and it appears to work well enough to make holding the throttle for extended periods far less a chore. <br /><br />It's not perfect (what is?), and I know I can make a more efficient adjustable assembly with either a set srcew or a control knob, but ... for now ... I'm good to go<br /><br /><br />Next on my list is a lateral tab for counteracting prop/steering torque. Little engines don't have adjustable tabs like their big brothers, but even small boat/engine combinations experience torque ... My goal is to have the rig run "trimmed out" at my favorite cruising speed. Eventually, I'll get there.
