How to check oil level in 2 HP four stroke Honda
fishon71
Can someone tell me where the oil level is to be on a 2 HP Honda 4 stroke? What position is the motor to be in when checking? What is the oil capacity? All I find is a fill & drain, no dip stick. Is the oil to be up to the top of the fill when engine is upright?<br /><br />Thanks
zzzzz
Re: How to check oil level in 2 HP four stroke Honda
there is a glass sight level on port side of engine...BF2A holds 0.42qt...BF2D holds 0.26qt...check level in vertical position :cool:
fishon71
So just as long as you see oil in the glass your good to go?<br /><br />thanks
zzzzz
Well - I just looked in the owners manual from a 2hp in the showroom and it says full is to the bottom of the center hole visible in the metal behind the glass :cool:
