92 waverunner III
vipper1413
Hey I got a quick question. I got this waverunner for $500, It runs perfect and is in OK shape. The only thing is when i have to start it i ned to put starting Fluid, weh n i do that it will run perfect all day and start right up I was woundering wut to do just to make it start up w/o starting fluid?
JB
Re: 92 waverunner III
Keep using that ether and it may never start again, steevo.<br /><br />Get a manual and learn how to use a choke or primer to get it started.<br /><br />Good luck. :)
Jeff Walkowiak
the easiest way to sovle the problem is to add a small primer bulb to the fuel line to your fuel line to your fuel pump and pump fuel to the carbs there are also primer kits or just buy start fluid with oil in it , try not to use straight either they make it with a top oil added for diesel engines, most times it is the fuel selector switch that is obstructed and it makes the fuel pump work hard to get fuel to the carbs after it looses it's prime, other times there is a loose hose fitting or clamp and it draws some air as it tries to prime the system, be sure all your hoses from the tank are tight.
vipper1413
Ok thanks. by the way anyone know where to get like hi perfromace parts for this thing? its pretty fast but the faster the better. Thanks
Jeff Walkowiak
It isn't a race ski its a family ski I would suggest you leave it alone and ride it till you get tired of it, any money you spend on it would really just be a waste, it's a 13 year old jet ski get your 500 bucks worth of fun out of it and don't monkey around with it.
firemanbill
I too had the same problem with a used yamaha i bought, i think overtons sells a primer kit for them, u take the choke plate off and mount this primer kit there and pump it from where the choke lever was mounted on the outside of the craft.
goldhunter_2
denniskrik.com you can get primer bulbs kits I Would also recommend you make sure your choke system is working corretly the older skis you need to replace th cable ome times
