Keith_Olivier
Thread starter- Joined
- Jul 13, 2005
- 2
Howdy all<br /><br />I have a 94 Sea Rayder that I bought with a defective engine. I sourced a nwe engine from Almars Outboards way out in DE and the new motor runs fine.<br /><br />Loking at the trashed out motor, I found that the cooling passages were partially filled with rock debris (small pebbles and shale). I have been wondering about the performance of the jet pump, since the engine I installed seems far too willing to rev up to the maximum. The pump doesn't seem to load the engine down suficiently.<br /><br />Looking at the jet pump, I have found that the wear ring is badly scored and I would estimate the radial clearance at 40 thou (minimum). The impeller leading edge seems in reasonable shape, but it appears that rocks got between the back of the impeller and the stator and that end is chewed up. <br /><br />I have the impeller which is threaded and no amount of torque combined with penetrating oil and some heat from a blowtorch appears to be able to encourage the impeller to come free of the shaft. Is there some secret method to free the impellor that someone could share?<br /><br />Furthermore, looking at the wear ring, it appears to be an aluminum casting with some sort of paint applied. A new wear ring is between $225 (Almars) or $275 (local Mercury dealer). Has anyone had their wear ring bored out and sleeved with stainless steel or another more wear resistant material ? Any tips about how to deal with the worn impeller ? It would seem feasible to cylindrical grind the outer face of the impeller and match that diameter when sleeving the wear ring. Anybody have some exerience with this ? <br /><br />It seems a curse that Mercury built their wear rings cylindrical without any wear liner that would be less expensive to replace. Yamaha et al all have less expensive systems.<br /><br />If anyone has dealt with this before please let me know how you did it.<br /><br />Thanks Keith
