kawaski 900 stx
jwr44
loses power after 3500 rpm but not all time. seems to be fuel but does not occur every time. changed to new gasx=, replaced filter. is there another filter and where would it be located any help appreciated. could this be cooling or electric issue thank you in advance for any input
Jeff Walkowiak
Re: kawaski 900 stx
have you looked to see if the chokes are sticking partially closed, also you could have a worn out fuel pump or a loose pulse tube to the pump,or a plugged up fuel selector switch, water in the fuel tank, loose fuel hose letting air in the suction side.
