GOOD NEWS. . . . The PICTURE UPLOAD FUNCTION IS WORKING !!! The tech folks at the parent company have been able to remedy the issue. You can upload pictures once again. Thank you for your patience.
Whutsa matter bubba...you to tight to buy one? <br /><br />I know...darn things are expensive. Afore I got fancy and bought one, I took a square of plywood and mounted four long screws from each corner aiming at the center. I ground the screw ends to a point also. In the center of the plywood, I rigged a post for ground with a large alligator clip comin' out the back. I could then adjust the screws for different gaps. All I did was run the spark plug wires to the screw heads, clipped the clip to a good ground. Crude...but it worked.
How 'bout the easiest way which educated me years ago:<br />Father: Son, come here and hold this for a minute.<br />Son: %*#%$!<br />Father: Good spark! Now go wash your mouth out with soap.
hahaha<br /><br />on the car, I just pull the plug, sit it next to something metal and watch for spark, sometimes gotta hold it with a pliers and hope the insulation is still good.
have done that father and son bit and I was the son and that is the reason I am deathly cautious of those things.<br /> My grandfather had a saying that you didn't need to touch something that ran thru a wire so fast you couldn't see it.
My dad ,god rest his soul, used to grab the wire and give the rope a yank. He would say "ouch, ouch ,ouch,ouch, watch the vain on my arm, ouch, ouch, ouch"
