LubeDude
Thread starter- Joined
- Oct 8, 2003
- 6,945
I do not want to get into an oil argument, but here is the best advice I can offer, and its not oil!!<br /><br />The best thing you can do, and most people do not even know about it is an UAO,(Used oil analysis)!!<br /><br />I think that whether it is a new car or you are buying used, the best thing you can do is to have an oil analysis done on the used oil at the first oil change! It is about $20.00 and is the best way to find out how the inside of your engine is doing! Mainly it will tell you if you have a bad head gastket or other problem that would allow antifreeze to enter your oil! NOTHING will wear out an engine like glycol!! It can happen with a new engine just as well as a used one!! I do not advise you to do it every time unless you have more money than brains, but it will tell you how well your oil is holding up and if you might be able to go farther on the oil change interval! No reason to change oil that is still good!<br /><br />a good dino oil will last 3-5,000, and a synthetic will go 5,000 + with better high temp protection and cold weather starting!! Dont go farther unless the bottle says that the oil is recomended as an extended drain oil!!<br /><br />Food for thought!!<br /><br />LubeDude
