FUEL PUMP
constance banks
1989 CHEVY ASTRO VAN WON'T START, WHEN i TURN IGNITION JUST A LITTLE, FUEL COMES OUT----I WAS DRIVING ALOMG AND IT JUST STOPED, I TRIED MAP SENSOR NOT IT, REBUILT THE FUEL INJECTION SYSTEM NOT IT
eurolarva
Re: FUEL PUMP
Could be almost anything. If I were to guess I would guess the ignition module. They tend to go and not leave a code in computer.
snapperbait
Re: FUEL PUMP
Do you have a service manual?<br /><br />What engine?<br />Got spark? <br />Are you getting any codes out of the computer? <br /> Did you jump/bypass the fuel pump electrical circut at the ALDL connector under the dash (ALDL connector is where you would connect a code scanner) to rule out a bad fuel pump, and test the fuel pressure with a gauge?<br /><br />Give us any info you can, and don't be afraid to get long winded with your post..
LubeDude
Re: FUEL PUMP
Probably fuel pump, they are inside the tank, normal problem with Astro vans!
SpinnerBait_Nut
Re: FUEL PUMP
Originally posted by SIN:<br />1989 CHEVY ASTRO VAN WON'T START, WHEN i TURN IGNITION JUST A LITTLE, FUEL COMES OUT----I WAS DRIVING ALOMG AND IT JUST STOPED, I TRIED MAP SENSOR NOT IT, REBUILT THE FUEL INJECTION SYSTEM NOT IT
SIN, you will have little fuel come out when line is open, but when under load, the pump will not provide enough fuel to run.<br />I take it you have the 4.3 with TBI on it.<br />Check, filter, strainer and/or pump.<br />The later two are in tank as has been said.<br />Also when replacing pump, replace strainer also as it will not be covered under warranty if you don't.
