Lean-too ?
SpinnerBait_Nut
Ok, if I want to build a 12X20 Lean-to off the side of my garage, how long would the lumber have to be coming off the garage to keep it at 12' wide.<br />Do I lose length when I have my slope away from the garage?<br />Do I need 14' lumber and have an overhang or what?
crab bait
Re: Lean-too ?
yeah, sure.. runnin' a board on a slant you'll lose lenght.. plus you'll need some workin' room..i.e. cuttin' a slight angle in 'em at the butt end.. an of coarse ,, lenght for your 'birds beek' notch/over hang..<br /><br />leantoo's always look better with a nice overhang.. <br /><br />14 footers will do nicely...
SpinnerBait_Nut
Re: Lean-too ?
Thanks crab bait.<br />I am making like I said a 12X20 with a garagre door and doing it in that fancy metal siding stuff. Gona put it on the garage too so it will all match.
Bigfun
Re: Lean-too ?
Depends on the height of your present garage and how high you want the outside wall of the leanto to be. Also the pitch of roof. If it's a heated garage and ice damns are possible in your region then the pitch of the leanto becomes important along with the type of roofing material.
D
DJ
Guest
Re: Lean-too ?
SBN,<br /><br />As Bigfun said. Need to know the height of your starting point (garage side) and your ending point (open end) height.<br /><br />Also, I would imagine that any snow you get there in Kentucky is pretty heavy and wet. A roof of as good pitch would be needed along with a roofing material that will allow the snow to slide off. Metal would work well.
SpinnerBait_Nut
Re: Lean-too ?
Well my starting point on the garage will be about 12 foot and hope to end up at about 10 foot on the other end.<br />This will be an enclosed lean-to with metal sides and roof and a roll up door on the front.
Bigfun
Re: Lean-too ?
The seam (no seam best)were the 2 roofs meet will be the critical point. Also most of the snow that slides off your present roof will most likely stop on your future roof. Tough to give relevent advise without the dimensions of your present garage. Side wall height? Amount of overhang/soffit? Pitch of roof? Truss width?
Fly Rod
Re: Lean-too ?
:)If the width of the building is 12 feet and you use a pitch of 5" rise per foot of run then you may get away with 14' rafters and have about a 6-8" over hang!!! Take a 16' piece of strapping and see what length of rafter you need!!!<br /><br />Also you may have to think about any windows on the side of the building that you are attaching to!! You may be limited to your roof height!!!<br /><br />When using regular roof shingles I wouldn't use less then the 5" rise for water run off!!!<br /><br />When fiquring your pitch and using 5" per foot of run, take 5x12= 60" or 5 feet from your top plate is where the top of your rafter height will be on the existing exterior wall<br /><br />Exsample: 5" pitch in 12 feet= 60"<br /> 4" pitch in 12 feet= 48"<br /><br />Any less then a 4" pitch then you need either a rubber roof or double coverage asphalt!!! ;) :cool: <br /><br />When repeling water I wouldn't use less then 5" pitch!!
ED21
Re: Lean-too ?
Take some measurments & draw a scale plan & section through the existing garage & proposed addition & you can tell exactly what heights the shed will be as well as rafter length. A little planning goes a long way to avoiding surprises.<br /><br />2x8 at 16" on center is probably a min for roof rafters. Check with building department if you need a permit. They are usually helpful. Lumber yard should have span charts too. <br /> <br />Shingles- 4/12 pitch min<br />Roll Roofing- .5/12 min to 4/12 max<br />Metal- usually about 3/12, some less
ebbtide176
Re: Lean-too ?
SBN i know you're joshing us all here. you know your length is gonna be all according to where you tie it into the other roof. ;) <br /><br />12' wide with 2' eave is 14' ya know. you need to figure how much pitch you want. probably not matching your house roof is what you're hoping for, to save space/wood. get someone up there with some nylon string to look at what you want. put a post out on the outside edge and look at the roof angle with the string to figure your roof. if you're tieing into the other roof, then you already know it won't be the same pitch, unless you're dropping the floor of the addition. :D <br /><br />you probably should not go less than 4/12(4'rise/12'length)<br /><br />hint: a2 + b2 = c2{sq} (14ft overhang sqrd + 4'8" high sqrd)<br />168x168=28224<br />56x56=3136<br />28224+3136=31360<br />31360sqroot=177.08754<br />177.0875/12=14.757295<br />14'8" rafter length(if it were tied in at edge of other roof, which ain't happening)
SpinnerBait_Nut
Re: Lean-too ?
I am going to tie into the side of the other garage with some 2X6's nailed up onto it.<br />All I am after is enough clearance to use a 9X7 garage roll up door on it.
Throbbin Rods
Re: Lean-too ?
The Pythagorean Theorem, as I recall, was Asq + Bsq = Csq. Measure from the peak straight down to the height of the Top plate. Square that number. Measure from the center of the house to the farthest point that you want covered by your overhang. Square that number. Add the two squares together, then take the square root of the result. That square root is the exact lenght from peak to end of new leantoo. Add on whatever you want for an overhang. And they said I'd never use this stuff!!
BinLurkin
Re: Lean-too ?
I think it's the hyoptenuse that you want. 12 feet don't seem like it will make it to me. What we need to know is the rise & the run, which you have, 5 in 12? 5 inches of rise per foot? Then if you have a rafter square you can figure it out off of that. The tables are stamped on them. Or I'll look it up for you in my book which is in the garage with my square at this time. Even that will only give you the length to the outside wall, you have to add some more for your overhang, whatever amount you want.
roscoe
Re: Lean-too ?
Just drop a few 50' pines down on the garage and use them to frame in the rest of the leanto with some maples and elms.
