Polishing Fiberglass
ehenry
Can yall tell me what would be the best and easiest thing to use clean and bring the shine back to an old fiberglass boat hull? Its a solid color with no glitter. The finish looks like its kind of chalked over if that tells yall anything. You can write your name with your finger on the side of the hull.
LadyFish
Re: Polishing Fiberglass
This might be information overload E.F. but hopefully you can extract what you need.<br /><br />Restoring the Shine to Fiberglass<br />by Don Casey<br /><br />The outer surface of a fiberglass boat is normally a special resin called gelcoat. Gelcoat has little structural value-the underlying laminates of resin-saturated glass fabric provide that-but gelcoat protects the hull and gives it its color and shine.<br /><br />When the gelcoat was originally sprayed into the hull mold, it-like any gel-took on the shape and texture of the mold surface. The ultra high gloss most new boats exhibit is due entirely to the highly polished, mirror-like surface of the mold used in the original construction of the boat.<br /><br />Time and exposure eventually erode the relatively soft surface of gelcoat, leaving it dull and chalky. Fortunately, the gloss usually can be restored.<br /><br />Cleaning<br />The first step in restoring the gloss to dull gelcoat is always a thorough cleaning. Add a cup of detergent to a gallon of water-warm water is better-and use a sponge to wash the surface with this solution. Be sure to protect your hands with rubber gloves.<br /><br />If mildew is present, add a cup of household bleach to your cleaning solution. Difficult stains like fish blood and waterline scum may require the direct application of a concentrated cleaner formulated for fiberglass. Rinse the clean surface thoroughly and let it dry.<br /><br />Degreasing<br />For dependable results from wax or polish, the gelcoat surface must be completely free of oil and grease. Detergents often fail to fully remove these contaminants from porous gelcoat. Wipe the entire surface with a rag soaked in MEK (preferred) or acetone, turning the rag often and replacing it when you run out of clean areas. Again, protect your skin with thick rubber gloves.<br /><br />Wax<br />Keeping gelcoat coated with wax-starting when the boat is new-is the best way to prolong its life. Regularly waxed gelcoat can retain its gloss for 15 years or more. The real purpose of a coat of wax is to protect, but wax also has restorative properties if the gelcoat is not too badly weathered.<br /><br />Application instructions vary among brands, but in general you apply the wax with a cloth or foam pad using a circular motion. Let the wax dry to a haze, then buff away the excess with a soft cloth, such as an old bath towel. The remaining wax fills microscopic pitting in the gelcoat and provides a new, smooth, reflective surface.<br /><br />Polishing<br />Polish is not a coating, but rather an abrasive-like extremely fine sandpaper. Polishing removes the pitted surface rather than coating it. Use a soft cloth to apply polish to a small area at a time, rubbing with a circular motion until the surface becomes glassy. After polishing, you should apply a coat of wax to protect the surface and improve the gloss. Some polish products include wax in their formulations.<br /><br />Using Rubbing Compound<br />If the gelcoat is weathered so badly that polish fails to restore its shine, you will need the stronger abrasives rubbing compound contains. Wax on the surface can cause the compound to cut unevenly, so first remove all wax by "sweeping" the surface in one direction-not back and forth-with rags saturated with dewax solvent or toluene.<br /><br />Select a rubbing compound formulated for fiberglass and use it exactly like polish, rubbing it with a circular motion until the surface turns glassy. The gelcoat on your boat is about 10 times as thick as the paint on your car, so compound shouldn't cut all the way through it as long as you are careful not to rub in one place too long. If the gelcoat starts to look transparent, stop.<br /><br />After the surface has been compounded, polish it, then coat it with wax and buff it. Providing the gelcoat has an adequate thickness-the boat might have been compounded previously-this process will restore the shine to fiberglass in almost any condition.<br /><br />Do You Need an Electric Buffer?<br />You can wax, polish, and compound by hand, but on anything but the smallest boat, your arm is going to get very tired. An electric buffer takes much of the work out of keeping a boat shining and is less expensive-and less painful-than elbow replacement.<br /><br />Electric buffers operate at relatively slow speeds, so don't try to "make do" with a polishing bonnet fitted to a disk sander or a sanding pad chucked into a drill. You will either ruin the surface or ruin the tool. A buffer with an orbital motion will leave fewer swirl marks.<br /><br />Restorer<br />In recent years a number of products have come on the market that claim to restore the surface of the gelcoat. Restorer formulations renew the gloss in essentially the same way as wax-by providing a new smooth surface-but without the need for buffing. Results can be dramatic, but because restorers are a plastic (acrylic) coating-similar to urethane varnish-they can wear off, flake off, and occasionally discolor. Restorer kits typically include a prep wash and sometimes a polish in addition to the restorer. A specialized stripper-for removing old sealer-is also necessary.<br /><br />There are variations in the recommended application, but in general it is the same as already described-clean, polish, and coat. The acrylic sealer is usually water-thin, so applying it to the hull is much easier than, say, pastewax. And it dries to hard film, so no buffing is needed. However, you do have to apply several coats-five is typical-to get a good shine. If the product you have selected doesn't include an applicator, use a sponge or a soft cloth to wipe the sealer onto the gelcoat. Drying times are short, so subsequent coats can generally be applied almost immediately.<br /><br />A multicoat application can restore the shine to weathered gelcoat for up to a year, but when it is time to renew it, you will need to remove the old sealer using the special stripper supplied in the kit (or available separately). Apply five fresh coats of sealer and your boat should shine for another year.<br /><br />Good luck! :)
LubeDude
Great find Ladyfish, that belongs in the FAQ!<br />--------------------------------<br />
neumanns
Any more Questions EFHENRY or does that cover it. :eek: :D :D :D <br /><br />LF after the mower debate I gotta ask did Mr.LF at least buy ya an electric buffer for the job? :p
LadyFish
Yeah right neumanns, its in the garage right next to my new riding lawn mower. :rolleyes: :D
TPD211
Prior to buying my deckboat I had 2 jetskis. One was red n purple. The dealership left it exposed to the elements when they were replacing the engine. It came back not once, but twice, faded with oil n grease stains on it. Red n purple fades pretty good, it looked chalky also. <br />I got some 3m marine wax/polish at Wally World. It has some "cut" in it that takes out the chalky layer without hurting the gelcoat. I used a orbital polisher on the jetskis. After the 3m polish, I used a good wax. This really brought out the shine to the red n purple. The wax I use is Zyoil (sp?), it smells like coconut and is oily.<br />Man does it shine, and it last a long time also. It's about 10-15 bucks a bottle. A little goes a long way.
ehenry
Boy Howdy, ASK AND YOU SHALL RECEIVE ! ! !<br /><br />Thankyou Ms Ladyfish.
salty87
harbor freight has an affordable variable speed buffer on their website. i've only seen more expensive ones in the store. delivery takes a few weeks but the whole deal will only set you back $30 to your door.<br /><br /> http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=46507 <br /><br />it comes with a velcro backing plate and tie-on type plate. i've used it and it worked just fine on my 23'er.
