tony_cliffy
- Joined
- Mar 19, 2003
- 182
I have a wimpy 110V arc welder that works well enough to make simple welds on smaller materials. It even works on rebar and pipe enough that I can make wreck anchors and other doo-dads I use with the boat. But even though it says it uses 1/16 and 3/32 rods I can only get the 1/16 rods to lay down a bead. The 3/32 rods just stick and stick and stick. <br /><br />The welder has an adjustment to crank up the power and I have it cranked up all the way to the maximum setting for 3/32 rods - it still sticks. I'm using brand new, fresh rods - whats the deal? I guess I can live with just the 1/16 rods but I know the 3/32 would give me a heavier bead and a stronger weld if I could get it to arc properly. <br /><br />Thanks for any advice other than 'get a real arc welder'!!!
