eurolarva
- Joined
- Jun 24, 2003
- 4,182
I have an old outboard with a cast aluminum power head. Because of some bad advise I took the exhaust gaskets off and three screws broke. When I tried to use and easy out and pb blaster the easy out broke. The original screws were 1/4 20. I have attempted to use JB Weld and re tap however I can not get the torque on these screws tight enough before the JB weld strips out. The walls around the screws are very thin now. Is it possible to fill these holes with an aluminum type welder and then retap them? The motor still blows 145 compression and runs great. I have seen welding rods for aluminum at Home Depot that will melt at 400 degrees and require either mep gas or oxygen to get them hot enough to melt. Is this a solution?
