testing thermocouple
dolluper
On a test of a termocouple for a gas furnace what is the range between good and bad would 10 millavolts be on the good side or closer to bad ,does anybody know the ranges Thanks a bunch
sangerwaker
Re: testing thermocouple
For the three bucks they cost, I just replace them if they are even in question. I never knew you could test 'em.
dolluper
It's not the cost as I always have a spare on hand but knowing if is faulity sure helps in figureing out what makes the pilot to drop and go out
Pascal
What is the voltage on the new one??? <br /><br />That would be good reference for the rest of us too.<br /><br />JD
dolluper
I guess L had brain fade ,found out if it's good it will read 30 millavolts buddy contractor inlighten me 10 millavolts would be bad
ob
They make a thermo-couple checker.I've got one left over from my A/C service days.The fitting that screws into the gas/safety valve attaches to the checker and you depress the spring loaded button on it for a ten count.If it stays depressed the thermo-couple is good.Most failures are a result of a heat cracked/stressed thermo bulb that hangs in the flame.<br /><br />Tip.. If you have an adjustable heat anticipator on you T/stat ,set it according to the amp rating of your pilot/safety valve.This will give your system the proper heat lag range.
dolluper
I don't think I can adjust the stat it is a digital programable one but I still have the old mercury one that is adjustable ,if the digital one can be set how do you do it any suggestions OB
To dolluper, the digital thermostats don't need the heat anticipator adjusted. They do it all "digitally".
