While I agree with you, I've been told that going by statistical sheets is not the only way to choose an oil. I said what other way is there then?Originally posted by Gil009:<br /> Valvoline. Better statistical sheets. Castrol isn't inferior, just not as good as Valvoline.
I think you missed my drift.Not knocking Mobil1 oil which I also used as a staple in the 94 Corvette,just that the two brands in question are not measureably different.The comment I made was somewhat of a play on words.For instance: "A drop of oil in the right place is better that two drops along side."Originally posted by JB:<br /> What does "dirty Mobil 1" mean? .
If you have the sheets... you have empirical data from which to compare apples to apples. Most manufacturers give little or no useable data. Like pulling hens teeth to get it. <br /><br />The only other way to select an oil really is by word of mouth such as... Well I have used brand x for 32 years and if its good enough for me its good enough for you! This doesn't always work. Usually doesn't. Just because you have used it forever doesn't mean its remotely the best oil for your engine. <br /><br />Oil is and has been for a few years my passion to research and learn about. I rarely get involved in these endless debates and flame wars because I know what I know and don't have an axe to grind. <br /><br />There is much mis-information on this subject <br />mostly due to the fact that many manufacturers really don't give real info short of the advertisements that are meant to dazzle you with their products painted on the hoods of race cars.<br /><br /> The oil business is cut throat and there is out and out deception on the part of more than one major company out there. They rely on consumers being loyal to them for the oddest reasons. Once you become educated... you lose alot of the brand loyalty fever. They don't want that. So in answer to your question, do your homework and and you will find that the companies that give the most information have less to hide. A good oil stands on its own merits. A bad one stands on Madison Avenue Circus commercials.While I agree with you, I've been told that going by statistical sheets is not the only way to choose an oil. I said what other way is there then?<br />
