Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
This is the second time my 275 gallon oil tank (in basement) has run out. But there is still about 60 gallons in the tank. Delivery guy said that the copper pipes in the tank don't go deep enough. There is a threaded fitting on the top of the tank with two copper lines attached to it with compression fittings. I want to unscrew the compression fittings, remove the lines and unscrew the fitting from the top of the tank to see what the length of the pickup and return lines are inside the tank. What will I find inside the tank? How close to the bottom of the tank should the pickup line go? How easy is it to put in longer lines?<br /><br />Thanks,<br /><br />Mark
