Re: a little help from BS expert please.
Chief, when I had the problem with the original magneto it was indeed intermittent. It would work sometimes, and sometimes it would not. The cheap foreign-made replacements, however, seemed to never work again, if I recall correctly, after they failed.<br /><br />A matchbook cover or notecard is about right for setting that gap, by the way. It should be set with the magnet on the flywheel under the pickup coils of the magneto.<br /><br />I will also add that I seem to recall having problems seeing the spark with the plug removed. No idea why that is.<br /><br />I'll betcha the magneto is the problem!<br /><br /><br />-dd-
