What is a normal compression for a BS mower engine, model 110900 (single cylinder, vertical shaft, 4hp)? I measured 90psi, but the guage I used was one you had to hold pressed to the plug hole (does not screw in). Also, I had to pull the starter rope with one hand while trying to hold the guage with the other. The true reading may be a bit higher. The engine seems to run good.<br />Thanks.
