Wanting to get Avitar here - All set! Thanks
Straightup
What sites do you recommend for hosting your pic for your avitar? I want to get an avitar up. Is there any inexpensive / free hosting sites that would work good for this?<br /><br />Thanks for any tips.<br /><br />Jeff
Re: Wanting to get Avitar here - All set! Thanks
I use this place,... Free.....<br /><br />It's for posting pic.s,... Not web Pages......Real Easy,+ Real Basic......<br /><br /> http://xs.to/
one more cast
just remember to resize your picture to around 100x100 first.
Straightup
Sounds good. Thanks guys.
Straightup
Still in process...<br /><br />Have pic on xs.to and is under 100 pixels x 100 pixels. Think it is 98 X 76 or so.<br /><br />Went to update my profile and put in select avitar. It sees my file, but only shows up as a red X in the box and also shows up that way in the forums on my screen :confused: :confused:
one more cast
test:
<br /> Make sure this is all that is in the address box. http://xxxxxxxxxxxxxxxxxxx.jpg <br /> And then click "set URL" and then click " update profile" way down on the bottom of the page.
Straightup
Thanks Bill and OMC!!!!<br /><br />Jeff
chuckz
This thread encouraged me to add an avatar. Let's see if it works.<br /><br />{EDIT} It does
Straightup
That's cute Chuck :) :)
brother chris
alright, lets see if mine worked.<br />I guess not!<br />Back to the drawing board.
notinbig
Testing my avatar
notinbig
I can change it and it shows it in my profile but the when I post its gone.<br /><br />Wierd, oh well no pic for me!
sangerwaker
Try a different picture host. For some reason, some don't work well. I've got a ton of space left on mine. Email the pic to me and I'll put it in my host server if you're interested, Jay.
BigPoppaG
That happend to me nothinbig. I did what sangerwaker said. Tried a different picture host and BAM Avatar works.<br /><br />This should be in the FAQ section. :D ;)
Straightup
I also found out you need to be patient. Once you are seeing it on your profile, it doesn't show up in the forums until about 10 minutes later. Maybe it was just because the forum was busy at that time, but I almost gave up again and a little while later it was there. If your pic is showing up in your profile, it will be on your new posts eventually.
BigPoppaG
Originally posted by Straightup:<br /> I also found out you need to be patient. Once you are seeing it on your profile, it doesn't show up in the forums until about 10 minutes later. Maybe it was just because the forum was busy at that time, but I almost gave up again and a little while later it was there. If your pic is showing up in your profile, it will be on your new posts eventually.
You are correct sir. This also happened to me. :rolleyes: :D
Straightup
Also, my avitar only shows up on my posts after I set it up and got it going. All my old posts in my past threads have no avitar :confused: <br /><br />Never saw that on a BB before, but maybe that is a way for UBB to save space.<br /><br />Glad I have it going now tho'... :)
