Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Just hooked up a 4 way light circuit in the basement. I don't have any recessed cans hooked up to the circuit, just a wire hanging from the ceiling. So I attach a neon test lamp with wire nuts to the feed and test the switches. Everything seems to be good, all the switches turn the neon bulb on and off in all the combinations of on/off. But I notice as I walk past the neon light that when it should be off it is actually glowing very dim. I put my tester across the leads with the neon bulb connected and it reads 17 volts across the black and white wires. Also 17 volts from black to ground and zero from white to ground. I flip a swithch and the bulb glows bright and shows 121 volts from black to ground. I flip the switch again and its back to reading 17 volts. Then I disconnect the neon bulb and test across the black and white and the tester shows zero volts. Same for black to ground and white to ground. Flip the switch and the volts read 121.<br /><br />So I am confused. I get a 17 volt reading on a circuit that should be open, but only if there is a neon bulb attached to it. Without the bulb, the voltage is zero.<br /><br />What is going on here?
