Re: Any one have a kiln?
If you "heat" it too fast, depending on the water content, yep, it can split. Don't use highest power level...kinda like not turning the oven to broil.<br /><br />I tend to use the 50% power level, a lot. That way you don't have to stand and watch it. <br /><br />I started by placing a "standard" quantity on the tray, then 30 seconds at 50% power, test the diameter (or humidity of the wood), then back for 15 or 30 seconds at 50%, test, etc.<br /><br />Yes, it is a pain to find the right time / power per quantity, but once done, you've got the task done in part of the regular time.<br /><br />Dowels swell, out of round... 12 sections, 1 minute - 17 seconds on power level 8, warm and dry and as close to normal as can be.<br /><br />If you do doll furniture or small bent parts...soak the area to bend in water...then nuke it, while it's warm, bend it. You can soak the area to bend in wet rag. <br /><br />Gotta watch the type of wood and the sap content.<br /><br />You just gotta experiment with it. And it's a whole lot cheaper to use than the oven or a kiln.<br /><br />Keep me posted on your results.
