Mark42
Thread starter- Joined
- Oct 8, 2003
- 9,334
Remember my basement finishing project? As part of that project the basement was insulated. Lots of air leaks around the sill were caulked closed. There are still some leaks, but the big ones were closed. <br /><br />As a result the basement is very comfortable. I didn't install heat in the basement, just what is radiated from the boiler. I leave the door open between the finished part and the shop where the boiler is and it stays warm. Upstairs temp is 69 F and basement is 68. <br /><br />This house was built in 1992 and the sole plate on the foundation is made from pressure treated 2x6 about 16 or 20 feet long. I found that over time they dried and shrank and left gaps between the butt ends about 1" wide!!! I could look right to the outside! No wonder som big bugs were walking around in here. I caulked up the gaps and also where the ouside sill plate meets the sole plate because there were major drafts coming in there too. I think that simple caulk job really cut down on cold air leaks. <br /><br />Seeing as I work in the basement one or two days a week (telecommuting) it is important to me that there are no big drafts or extra heat needed.<br /><br />So far, so good! I'll see how warm it stays when the temps drop into the -20 range.
