? On cleaning the "permanent" wick on a humidifier
Limited-Time
The wick appears to be expanded aluminum or some like material. After a year’s use it's coated with a yellowish/green funk that I have not been able to remove. (The wick is a "Lifetime" deal and finding a replacement has been no easy task.) I have tried Bleach, CLR, ammonia, and several other cleaners to no avail. Herself refuses to use the wick due to its unsightly appearance, :rolleyes: proclaiming "It can't be healthy if it looks like that! I though about boiling it in an attempt to dissolve the deposits. Any thoughts???
JB
Re: ? On cleaning the "permanent" wick on a humidifier
Vinegar or ZAP.<br /><br />I complained that my disposable wicks didn't perform as well as new ones after cleaning with vinegar. Well, I was reusing the vinegar too many times. When I used fresh vinegar the cleaned ones perform as well as new ones. Submerge the wick in the vinegar for an hour or so.<br /><br />If vinegar didn't work I would use ZAP or similar oxalic acid preparations. They dissolve hard water deposits very well, but might also dissolve my fabric-like disposables. I think your metallic wick would be alright.<br /><br />Good luck, and let us know the outcome. :)
