JB
- Joined
- Mar 25, 2001
- 45,907
Bruce Crower, (one of we OLD farts at 75) famous for his aftermarket camshafts, has patented a six stroke engine that improves efficiency about 40% and needs no cooling system.<br /><br />Here's how it works:<br /><br />After the exhaust stroke of what used to be a four stroke engine, and with both valves (or all four) closed, he injects water into the hot cylinder. The water flashes to steam and produces a second, steam driven, power stroke. That uses up the residual heat in the cylinder that is wasted in a four stroke. The next (sixth) stroke exhausts the steam and a "normal" four strokes follow.<br /><br />Of all the schemes to capture and use the wasted heat and/or energy from two and four stroke engines that I have seen, this one makes a lot of sense.<br /><br />Adapted to a DFI engine or Diesel engine Crower estimates a 40% improvement in fuel efficiency over conventional 4 stroke engines. <br /><br />To review:<br />1. intake<br />2. compression<br />3. combustion<br />4. exhaust<br />5. steam power<br />6. steam exhaust<br /><br />Both 2 stroke and 4 stroke spark ignition engines are technically "Otto cycle" engines and both 2 and 4 stroke compression ignition engines are "Diesel cycle", but Crower's engine, it seems to me, should be called "Crower cycle" engines.<br /><br />It also seems to me that Crower cycle engines will need more cylinders to run smoothly.<br /><br />There is a write-up on page 5 of this week's Auto Week mag.<br /><br />Whatcha think, guys? I think I want to make one!
