Re: New Computer Build UPDATE! ... V3.0
Well, Zach, you nailed it. (Yeah, the drives are new.) I needed to setup and load to the first RAID partition, then load Win XP, then define the second RAID partition.<br /><br />In retrospect, it makes sense. Need to first tell the bios the disks are configd as RAID, then define the first RAID partition (the ctrl I option you mentioned) so that Win XP has a place to load to. The motherboard needs the RAID driver (the F6 option) in place to toss around the data on the disks when loading Win XP, but Win XP has no way of understanding
Matrix Raid until that driver is loaded AFTER Win XP is installed. I was putting the cart before the horse by trying to setup Matrix Raid before loading the Win XP and the Matrix driver<br /><br />1-in bios define SATA mode as RAID. Reboot.<br />2-ctrl I to define first RAID partition. Reboot.<br />3-load Win XP. (At this point the sys functions as single partition RAID.) <br />4-load Matrix Raid driver. Reboot.<br />5-ctrl I to define second RAID partition (aka Matrix RAID). Reboot.<br />6-use Win XP Disk Management Utility to mount the second RAID partition.<br /><br />After mounting the second RAID partition the system is set up with MATRIX RAID. Its a lot of work, a PITA to figure out, but its a phenomenal scheme. Im using two 300gb HDDs. Matrix RAID let me set up 30gb at the front of each HDD to use as a 30gb system/OS space that is mirrored on each HDD. IF either HDD fails, the system isnt dead, can be booted from the other HDD. The remaining 250gb on each HDD is combined into a RAID striped scenario that gives me 500gb of free HDD space.<br /><br />Thanks for the help!!!
<br /><br />I have a couple of ILDVR DVR boards, now to decide on the CCTV cameras
<br /><br /><br />Edit: things I never figured out why:<br /><br />1-when installing Win XP, I opted for NTFS, not FAT32. If I selected full format, after formatting the partition Win XP says it cant format - disk may be damaged, or disk doesnt exist no disk detected, etc. But if I opt for quick format Win XP does it thing then loads to the HDDs as it should.<br /><br />2-dont know what was going on with the Plextor DVD/CD. After getting Win XP loaded I put the Plextor drive back on the system and all is well, works with no problem.
