technostingray
Banned
- Joined
- Jun 1, 2005
- 4,666
I went out to start repair on the rental but after loading the truck and trying to put her in gear the clutch pedal stayed on the floor but would not disengaged. Any quick fixes on this one?
No.Originally posted by JB:<br /> Is the clutch master cyl dry?
See: Can't back up from a given siteOriginally posted by Reel Poor:<br /> Fill the clutch master cylinder with fluid (brake fluid) and then pump the he!! out of it, Ford say about 100 times to get a pedel. Bleeding may or may not be necessary. If it's empty there is a reason for it, they dont use the fluid up.
Thanks Ken, Jerking the pedal worked for a while but the the Slave cylinder gave out completely. Good thing it not a newer model where the slave cylinder is inside the transmission.Originally posted by Kenneth Brown:<br /> An 83 has mech linkage with a z bar. You may try to jerk the pedal up and down a couple of times or crawl underneith and tap on the bellhousing/linkage with a hammer. It sounds to me like the throwout bearing is stuck.
