1997 johnson 150 jack plate need help
90srtatos
im a newbie to this stuff if i install a manual jack plate ,will the tilt and trim on my motor still raise and lower my motor as if no jack plate was installed thanks
Dhadley
Re: 1997 johnson 150 jack plate need help
There's that echo again.........
90srtatos
couldnt get no one to answer
90srtatos
whats does that mean echo again , you r funny hahahahhahahahahahahaha or just a smart a$$
Dhadley
The exact same question is posted in another forum and was answered correctly. You even said "thanks" and "that was all I needed to know". <br /><br />I just figured this post was an echo. They should have used more insulation when the built this room.
90srtatos
thought i might have posted in the wrong place at the time i didnt have any answers so i posted here
The engine is bolted to the jack plate instead of the transom. Certainly your trim system will still work.
gatorred
try manual for cmc 65 this is transom power lift read install on it its on there websight and can be download here <br /> http://www.cook-mfg.com/plfeatures.html <br />this is who makes cmc and is there websight down load the page on running it and setting it up manual side it in there
walleyehed
Just so you know...you just hammered the most highly experienced member on this forum...<br />His years of racing and collection of trophies and awards, not to mention his many other accomplishments, has helped THOUSANDS figure out more problems than you will see in your life.<br />Dhadley has forgotten more about boats than most of us will ever know, and as a member of this forum, I think you owe him an apology.<br /><br />EDIT: I had another thought...he knows more about YOUR boat than you do....fact.
gatorred
I just wanted to make sure it mounted right that was most of my problem this manual helped me If I was steeping on some one I am sorry
walleyehed
Not you, gatorred, I meant 90stratos...ain't nobody gonna call DH a smart azz..we all know his humor, and just like a Mod would have said, the question has already been answered..
