Propeller number?
scotttu
Volvo AQ131D and 275 Outdrive:<br /><br />Found this stamped on the propeller:<br />C 851139<br /><br />Is this a part number or year size and pitch?<br /><br />As most of you know I've been suspecting my prop is not the correct size and/or pitch..<br /><br />Thanks,<br /><br />Scott
Haut Medoc
Re: Propeller number?
Sounds like a part #....Don S. will know...Jk
skiriver
Just a suggestion, go to the Volvo-Penta website. From there you can establish contact with the factory, or a dealer, who can give you the correct advice.
scotttu
I emailed a gentleman at Midwest Propellers and this was his response, what does this sound like to you all, normal or too (something or another)....?<br /><br /><br />Scott, according to my book, that prop is a 14 diameter by 21 pitch. <br />.<br />.<br />.<br />.
Dunaruna
According to the michigan wheel cross reference chart - it's a 14x21 RH.
scotttu
But my question is, is that normal for a 275 outdrive driven by a 2.3l 4 cylinder?<br /><br />Or is it too much prop?<br /><br />thanks,
walleyehed
First, ya gotta know what your max Recommended WOT is....If the prop allows you to hit the max or within a 100RPM of it, yea, it'll do the job.<br />There IS NO SET PITCH for any particular set-up.<br />Simply run and verify data, then, your question will be aswered. :)
scotttu
Well WOT is supposed to be 4500-4800, the mechanic locally thought 5000 but that seems a bit high.<br />He said off top of his head that a 14x17 would be good, and then Bob at Midwest Propellers just emailed me the same info.........plus they are having a sale....<br /><br />So I'm going to drop to a 14x17 and run with that for a while, next spring...... :) <br /><br />I still got a carb to rebuild and some TLC to give to the engine and outdrive.<br /><br />Thanks,
Haut Medoc
Scott, 14D X 21P is too much for that poor little motor....Change it & see what it does...Why are you waiting till next spring? :p The sun is shining right now! :D Hopefully the new prop (14DX17P), will get you into the right WOT range....I would try the new prop before I did any carb work though....That way you will know exactly what its' effects are. ;) One thing at a time.....JK
scotttu
Well I agree with ya, hate to winterize JUST yet but I've got SO much going on right now, school, being sick, work, etc......plus I'm building a bathtub racer....(You should get one and come race!)<br /><br />Plus i don't HAVE a new prop yet :D But I'm going to order it, $153 new from that place I mentioned (Midwest).....<br /><br />Plus I know hte accelerator pump is not working on the carb, hard to start, no gas smell, no visible gas when throttle is pressed, and I can't see it squirting.....<br /><br />You still out boating then?
Haut Medoc
Yep, since I am FWC. I won't pull it out till the end of next month...They reopened Dungeness season, so I will go out when I can, the locks are pretty quick this time of year, and there is still plenty of crab to be had......JK
scotttu
Well I got my prop on order, should be here by Thursday next week, and got the carb kit ordered, should be here by Tuesday.<br /><br />So with any luck I'll have my boat back in teh water by SATURDAY :D at least for a trial run and to burn some gas up......then it'll get a fresh tank and get put away ;) <br /><br />Don't do much crabbing myself, will do salmon fishing next year though! And then there's the bathtub races.....(Still building my boat)<br /><br />Winter boating project.<br /><br />
scotttu
:D <br />I'm going with Merc, the Canadians love hte Suzuki's cuz they can spin them up better, I guess they run good too......<br /><br />
scotttu
Here's a pic of one running full speed ahead.<br /><br />Mine should do bout 32-34 mph if I build it right, but the modified class can run upwards of 40mph...<br /><br />
