Should this prop fit my 850?
SeaKaye12
Hi,<br /><br />I have a 1977 Mercury sn#4721196. 85HP. It's a 15 Spline<br /><br />Will this Merc Prop fit it?<br /><br />48 77342 A40L 15P<br /><br />Thanks...Chuck
walleyehed
Re: Should this prop fit my 850?
If your engine is a 4 cylinder, yes, it should fit. 1972-1977 85HP 4 cylinder.
SeaKaye12
Thanks walleyehed...<br /><br />Another question that just came up...<br /><br />What is the difference between:<br /><br />48 77342 A40L<br />and<br />48 77342 A33<br /><br />Better yet....where can I look up this info and save you guys the trouble?<br /><br />(Yes...my engine is a 4 cyl)<br /><br />Thanks agaion, Chuck
walleyehed
The # after the "A" is either blade shape or area.<br />The A40L may be a left rotation...make sure it IS a right-hand prop.<br />The merc parts express may have some numbers on their site, I'm not sure...
SeaKaye12
Well...Would a Picture enable you to tell me if it's a right-hand rotation? <br />
<br /><br />Anywhere I look on the Merc site...the prop selector stops around the year 2000 :( <br /><br />Thanks again, Chuck
SeaKaye12
MaxRules has the listings up to 1974...mine's a 1977...so near yet so far...<br /><br />Anyone know of a parts listing similiar to MaxRules that goes into the 1977 models?<br /><br />Thansk again, Chuck
walleyehed
Yes, that's a RH prop.<br />It should go right on......
gatorred
my 80 hp runs a 4 blade comprop 19 pitch it was slower then the 3 blade sr-01-0382 is number its not bad price either, now its in shed if it goes on,i need stainless steel because of jackplate on bass boat
walleyehed
According to my Merc book, the -33 is a pressed rubber hub and the -40 and -45 are flo-torqII props....same dia. and pitch....both BlackMax series.
imported_bjs
where do ya find all this info at.are those pressed in hubs replaceable?
walleyehed
I have Merc's Factory prop guide..<br />The press-in hubs are a prop-shop item...usually 40-60 bucks.
