Re: How do I take off my Prop off
Welcome!!<br />You probably have the lock-tab ring on yours....there will be 1 or maybe more, of the tabs bent down into the slots of the prop hub, I find a pair of channel locks work best to straighten the tabs, then, put a socket/rachet on the nut, back it off, and the nut and lock-washer come off. pull the prop off and there should be a large washer that stays on the prop-shaft, that's your thrust washer....<br />when you get the prop off, clean the shaft and splines good, then before you re-install the prop, grease the splines good with wheel bearing grease. Slide the lock washer on, then start the nut...the nut will fit into the recessed lock washer so you may need to hold the washer out to fit the nut until it's on far enough the washer stays in the proper position with the nut. Put a piece of 2X4 under the AV plate and let 1 blade rest against the wood while you tighten the nut...just snug it down, remove the wrench/socket, and see how far the next closest slot the tab will lin up with, and tighten to that point. Use a punch and a hammer and tap the tab down into the slot just enough it won't let it turn and you're done.
