jameservin
- Joined
- Feb 6, 2006
- 70
My new (used) boat is a mod v flat bottom (6degree rise?) sea ark 18ft 96in beam with a 115merc (boat rating=90-140hp. Weight=750lb + 325(motor)=1100. <br />Having blow-out at holeshot and in turns at most any speed. <br /><br />Found that SS 19P (used-that came with boat)is underproped (above 6000rpm), found 21 alum (std Mich wheel)close at 5600.<br /><br />Still terrible blowout in turns and at holeshots.<br />Motor AV plate is even w/keel. <br /><br />I have come to learn this hull is prone to blowout with bigger motors, but what can i do to decrease ventillation? <br /><br />Trim motor all the way in- theres still ventillation.<br /> <br />What prop type/design/3or4blade(?)should i consider to help fix this??<br /><br />Next plan to take some these props to prop guy and check pitch/rake, etc as they are used-may have been modified.<br /><br />Should I be looking for a high cup/rake to solve this issue?<br /><br />thanks.
