Re: evinrude 40
Its easy to check throttle opening. Move the throttle lever full open. Remove the engine hood and look at the port side of the carbs. There is a roll pin in the end of each throttle shaft that sticks through the carb. Both of those roll pins should point straight up. If they point slightly forward, the throttle is not opening fully. If they point slightly backward, the throttle is opening too much. Either way you need to do a link&sync. For that, get a manual as its far to detailed to go into here. As I mentioned very early in this series, once you start fooling with engine height, a water pressure gauge is a must because you approach a very fine line between being "ok and losing water pressure".
