Yamaha Outboard Props
cs90453
I have a Yamaha with a 13.25 x 17. I was going to get a faster prop but I'm not sure how the numbers work. I know the 17 measures the speed but does the number increase or decrease to get a faster prop?
Ron G
Re: Yamaha Outboard Props
Well the 17 is the pitch everthing else has alot of varibles.Whats the motor,whats your wot and your speed,what kind of hull.
The first number (13.25) is the diameter of the prop. 17 (Pitch) is the theoretical distance the prop would move the boat in one revolution. In this case 17 inches. To go faster one needs a prop with more pitch. BUT -- the motor only has so much power so increasing pitch may actually slow you down because the motor can't reach its maximum recommended wide open throttle RPM. Conversely -- going less pitch gives you great hole shot, but can cause the engine to over rev on the high end. Read the first post on this forum to learn what's required and why for determining prop selection.
