omc prop troubles
allforbob
I bought a 1979 Glasply 17ft. with a 140 omc. As stupid as I can be, I let my son take out the boat, and he spun the hub in the prop. I took it down to the shop to have the hub pressed, but the prop was old and it fell apart. So, I bought a reconditioned prop, the same pitch and diameter. Now it seems like when I take off it feels like Im towing something. It takes forever to get up on plane. I thought because it was an old boat, it had water under the floor. So I riped up the floor, put in new foam, and glassed it all in. I went through the sterndrive, new bearings,seals and a new waterpump.I took out the fuel tank, cleaned it, new fuel pump,and put in a new water seperator filter.and I still cant get it to come to a plane in a reasonable amount of time. You have to have someone crawl out on the bow to get it out of the water. The prop I got has no cupping to it. I might change the prop to a cupped prop Any suggestions?
Dhadley
Re: omc prop troubles
Welcome!!<br /><br />There are many different styles of props that have the same pitch. You can try 2 props of the same diameter and pitch and the 2 are as different as night & day.<br /><br />Now, that's assuming the motor is still running up to par and everything else is right.
allforbob
everything is still ok, but I wonder how much fuel Im using @ 3.40 a gal to do this. if I cant figure it out, It is just going to have to become yard art.
allforbob
They were both omc props, but the new one had no cupping.
walleyehed
That would be a very old OMC prop if it was not cupped....P/N would be inside the hub...should be able to read it, but you may have to remove nut and washer to see it.
cougar1985
as far as i understand ,cupped props will help you get out of the hole better and you will be able to stay on plane at a lower rpm than non -cupped.
whywhyzed
Banned
I've never seen a prop for a 1979 400 series that was not cupped.
walleyehed
There were alot of uncupped props made, but lets see if he can get us a P/N, then we'll know where we are.
