Turbo, or Stiletto??? 3 or 4??? (Kenny/Dhadley)
Boilermaker
Re: Turbo, or Stiletto??? 3 or 4??? (Kenny/Dhadley)
Originally posted by Dhadley:<br /> I'd like to try a 4 blade. In fact I thought I had one but I don't. Well, I do but it has a Yamaha hub so that's not doing us any good.<br /><br />So.......I guess we're back to what you've already been talking about -- a 15 3 blade.
Maybe NOT>><br /> Dale, can you recommend which 4 blade prop I should try??? :confused: :confused: :confused: <br /> If it doesn't work...I'm sure I can always resell it.
walleyehed
I may possibly know where a set is, but I'm not sure of the condition...
Boilermaker
OK Guys>>>if 4 blade, are we talking 17" pitch?
OR 15"?
Are we talking about raising the engine to the last hole? OR will it be that I can trim up more?
I know we have been dealing with a quality S.S. Prop, and I don't have a problem buying another, >>>but do you know anyone that has one of the SOLAS AMITY 4 blade props that are for sale here at Iboats?
If I get the S.S.4 blade, should I get the TURBO or the STILETTO...and what model of prop do you recommend ???
THANKS AGAIN
Boilermaker
OK >>> its UPDATE TIME!
I got a new TURBO 3 blade 13.25 x 15 and its like a different boat! it jumps right up onto plane, and just excellerates to top speed in a few seconds. I had a heavier then normal load onboard (extra guy fishing) and I was amazed at the difference.
I had a hard time getting an accurate reading from my tach because my eyes were tearing from the wind & the area I was boating in was VERY congested (4th of July weekend) so I didn't want to be starring at the tach.
From the sound of the engine, I would say I picked up about 200-300RPM. I also had my Bimini top up with the front & side "curtains" so there was a lot more drag there too. I DID loose 2.5 MPH top speed>>>but I don't know if it was the added load, or the pitch.
What really amazed me was that with the 17" pitch Stiletto prop, I could only trim out about 3/4 before the prop would loose bite & the steeringwheel would try & pull out of my hands. I would have to trim in before turning, or the prop would just vent badly.
With the TURBO, I could trim out all the way>>>this is with the engine at the same hight, 1 hole from the highest setting. I could turn HARD with this prop and still not vent! Makes me wonder about a 17" pitch Turbo?
I will post a more accurate (apples to apples) results when I run the boat with my usual load.
8)
Captain Tuna
I replaced my 15 pitch prop with a 13 pitch Turbo over a year ago (walleyehed's advice) on a 1969 trihull, 60 hp Rude. HUGE difference! MUCH better hole shot, MUCH better handling, same top end with a few more rpms. Jerks my old bod up on one ski (with only 60 hp, Thank you Walleyehed!). I find it odd that they didn't tell you to try a lower pitched Turbo on the first couple of posts.
Breaker 19 for Mr. Obvious, got your ears on?
Captain Tuna
walleyehed
Glad to hear both of ya's had good results!!
Thanks for postin' back...that's how we all learn.
