1969 Starcraft Offshore V
jjme2
I'm looking at a 1969 18' Starcraft Offshore V with mercury 1000 100 HP outboard, electric trim 3 years old, decent trailer, needs new wire from control to motor, seats will need reupholstered soon, but otherwise in pretty fair shape, motor run good. <br />What is it worth? 1200-1500-1800???
Reel Poor
Re: 1969 Starcraft Offshore V
Its very hard to say without beable to see the boat. Considering the age and condition you describe I would be thinking 600 to 1000. There is a lot of other things to consider when buying a boat that old, mainly structure condition that cannot be seen. Being that old it may need to be completely rebuilt new stringer and floor. I cant see it so I dont know, just beware. It could be a project boat.
jjme2
The floor seems solid. I can't see below the floor of course, but it looks like it might have been stored inside till just the last year or so. The current owner had it 3 years.
Always Broke
I decided to name my 1973 Starcraft Chiefton, Snowball. That’s the effect it’s had so far, I knew I was taking on a restoration project but ran into a lot of unexpected surprises. I pulled the lower unit to replace the shift cable, it has a Mercruiser I, and the water pump for safety’s sake. The exhaust, water feed, drive shaft hose were dry rotted. The transom looked fine until I saw a water stain by the inside nuts on the lift eyes, I poked at it and found there are two pieces of plywood layerd on top one another the visible one was fine the one behind it was rotted, LOL, sometimes you have to laugh so you don’t cry. Then what I thought was a lifter noise turned out to be something deeper in the engine, even though it was tinny sounding and not your typical bearing knock, when you disconnect the plug wire the noise just about disappears and the noise gets worse with higher RPM, probably a cracked piston or piston slap, either way time for an engine rebuild. Not to unexpected but still an expense I didn’t want. I’m not going into everything that happened here, I learned to take that stuff in stride because it’s what restoring a boat is about, but it adds up in the long run. A cheap boat turned into an expensive boat, I’ll probably have about $2000.00 or so in it when it’s completed because I’m doing the work myself and have a source to get dealer pricing on parts. I’ll know the boat is fresh and done right, which will give me a bit of confidence when I have it offshore. Always expect the unexpected and price the boat accordingly.
jjme2
Thanks, Guys for the info, I havn't make up my mind yet. I might make him an offer. Just don't like to upset people when I'm buying things
Always Broke
You can always go up with your offer, it's hard to get them down after an offer was made and you go down the road and see a better deal, the worst he can do is say no, X amount is the least I will take. Good Luck!
jjme2
Well, I am the new owner of the old boat.<br />I made him an offer, and he took me up.
NOSLEEP
Hope it works out well for you Old Noah.<br />Boat projects can have a way of warm'n up to ya. <br />The quicker you get started the closer you will<br />be to the pleasures of boating life.<br />Good luck.
Reel Poor
Well I guess congratulations are in order. Keep us up to date with how things are going. ENJOY :)
Always Broke
Congratulations! Can I have the first ride? :D Be patient and if you get in trouble you know where a bunch of fellow boaters are who are willing to help, Good Luck!
jjme2
Hey Thanks Guys, I'll have to wait a while to work on it, then clean it up and see what I've got, fire up that motor , then tune it up, I need some seats. It has lounge seats. I'd like to set it up a little more for fishing, but I will have to see what I can find cheap.<br />Later.
