Johnson 90 prop ?
tbrracer
I have a 25' older style pontoon boat sits low to the water... Johnson 90 on the back i need a new prop I took the prop off and the only letters I can find are under the washer and nut that held it on.
"Michigan pj 80" thats the only letters I see unless Im not looking in the correct area. The prop worked good just a little banged up so I want to replace it. Any ideas??
Thanks
cougar1985
Re: Johnson 90 prop ?
are there no numbers on the side of the prop atall? for example 13x15p.
