ok. After reading a bunch of posts i was convinced my lower shift cable was bad. when i shift into gear my interuppter switch makes the boat stall. i was told it was my lower shift cable however the cable shifts with ease. i have no trouble shifting with my hand if i disconnect the cable. my boat is an 87 and as far as the esa module, i have a two little boxes with butttons on them. one box has a lever on it which activates the esa and makes the boat stall. the other box from what i have heard.... has a button which is supposed to make the boat run smoothly when pushed. i hope im not confusing anyone. anyway the one little box works correctly. push the button boat stalls. the second box when the button is pushed it does nothing. im thinking that its suppsoed to make the boat run smoothly again. instead the first box button is pushed and the boat just stalls. do i have to replac the whole think of just the little box. i dont know what to do. right now i have a toggle switch to disenagage the esa module when shifting into gear so i can use the boat. i would love for this thing to work correctley. im very confused.
