Re: 2002 YAMAHA 50 HP 4 STROKE PROBLEMS
GOOD I REPLACED EVERYTHING THAT COULD BE REPLACED WITH THE CARBS. I FOLLOWED THE MANUAL ON SYNC THE CARBS AND SETTING THE MIXTURE SCREW. THE POPPINF SOUND IS GONE, WHEN IN THE WATER I REV THE RPMS UP TO 5900 PERFECT BUT ONCE IN GEAR STILL THE SAME STORY. I REPLACED PLUGS, CHECK COMPRESSION EVERYTHING IS GOOD. FUEL PUMP OVER 3 PSI. ANY IDEAS PLEASE HELP
