2001 Mercury 40hp stalls
lacroix123
I have a 40 hp 2001 2 stroke, It idles fine but when i throtte it , after a few minutes of running maybe 5-10 on average it stalls. I have aready changed primer bulb. when i did this it ran for 2 hours no problem, Now that i put it back in it ran fpr 5 minutes and stalled like there was not enough gas getting there. If I manually choke the engine it also starves. Can someone help?
JoeW
Re: 2001 Mercury 40hp stalls
I once had a similar problem. It turned out to be a very small split in my fuel line. What made it more difficult to detect was that the split was on the side of the fuel line that faced the hull.
You're not very clear on when it stalls. Are you at speed when it stalls, or at idle? Watch the primer bulb when it begins to die. If its being sucked flat there is a restriction in the fuel system between the primer bulb and the pickup in the fuel tank. Tank vent open? Does the engine restart after stalling? When it dies does it sputter a little and then die or does it quit like you turned off the key. Give us some help.
lacroix123
[quote time=1151856473 user=lacroix123 uid=78825 fid=29 tid= rid=0 We are at top speed the bulb stays in good shape.
OK - but does it sputter a few times and die, slowly reduce speed and die, or simply quit like you turned off the key?
lacroix123
[simply quits like i hit the kill switch, when i restart it it runs at low rpms if i hit the prime button on the key it runs at a higher rpm for a few seconds then back to bare minimum power. We ran it once for 5 hours no problem now that we put it back in it has this annoying prblom
lacroix123
ok here it goes one more time if i hit the prime on the ignition key it runs but not at full throttle it stays at low rpms. FUEL PUMP?????
i'd say yu have something electrical is getting hot and failing. do you have good spark when it fails?
lacroix123
good spark , not hot when it fails. it starts right back up and like i said it runs great at idle. 750-850 in gear low. just when i hit the throttle she bogs down and dies. If i try to squeeze the bulb its hard and wont push any gas. when i prime oqginally it pumps fine.
lacroix123
[one says electrical, one mechanic sayscarb rebuild, one says fuel pump any guesses?
lacroix123
[Good Guess but unfortunatley already changed it Thanks
lacroix123
just checked all fuel lines and sent a weedwacker wire thrugh them no junk. still doing it can anyone help??\
Plainsman
I thought I had a fuel problem, but mine wouldn;t even start. It turned out to be the switchbox. Did you use a inline spark tester when you tested for spark?
lacroix123
yes inline tested. i think i may resolve this today and post the results.
lacroix123
RESOLUTION: High speed circuit only clogged after 45 second run, sent to marine cleaned carb again. we will see this weekend. Thanks all for your help!!
Kevin W
Ethanol based gas issues?
i have a brand new gas tank that had new gas put into it and after a month it now has water in the gas.
E10 gas pulls moisture from the air and puts it in the tank.
check for water in the gas.
lacroix123
Check valve in oil pump is shot sorry you were all wrong
