hydrofoil for "getting on plane faster"
bryancx94
I am considering purchasing a hydrofoil to get my boat on plane quicker, I have a 94 90HP mariner on a 16' fiberglass vhaul starcraft. I took it out yesterday and it takes about 14/ to get it on plane, then once on plane it gets up to about 40mph (top speed) no problem.
My question is, will a hydrofoil help this issue. Also is there anything I can do to get more speed out of my engine. I remember when it was brand new it was able 50mph hit 50mph. The prop is aluminum 3 fin, and in good shape. Thanks!
WillyBWright
Re: hydrofoil for
Re: hydrofoil for
I'd find the source of the power loss before throwing gadgets at it. Make sure it's running on all three. Sounds like one cylinder is on holiday.
bryancx94
Re: hydrofoil for
Re: hydrofoil for
yeah I was going to do that.. since a hydrofoil is afforable i thought it wouldn't hurt since the engine is a little bit older.
steelespike
Re: hydrofoil for
Re: hydrofoil for
As Willy says check the motor for performance issues.
Could be as simple as a bad sparkplug.I've had good luck with foils but they should be considered a last resort after tuning,trimming and balancing weight.
And then you should seriously consider the Smart Tabs.A much better solution to performance issues.
Your motor isn't performing poorly because of age it has
some sort of problem.
bryancx94
Re: hydrofoil for
Re: hydrofoil for
My boat says a max of 825lbs ... I noticed yesterday anything over 500lbs it would barely get on plane, is this normal? its a 3 cyc engine, I had two people in the front, and it would still not get on plane. I will check the spark, on all three plugs ... what do u think top speed should be on that boat?
bryancx94
Re: hydrofoil for
Re: hydrofoil for
I saw the smart tabs for about $175. Are they a lot better than a foil? are there any negatives about installing a foil on my engine?
WillyBWright
Re: hydrofoil for
Re: hydrofoil for
Lots of negatives. Every time you touch the trim button or turn the steering wheel, the hdyrofoil's characteristics change. Tabs stay put and don't mess with your handling. Hydrofoils also slow you down by 2 to 4mph, tabs don't slow you down at all. In fact they can even help the boat go faster.
You might be overpropped. 40 is about what I'd expect. Check your prop's pitch. Educated guess would be a 19" for speed and 17" for power. 15 would probably be too low and 21 too high. But it all depends on the boat and motor setup.
bryancx94
Re: hydrofoil for
Re: hydrofoil for
So with the smart tabs installed, you still use the motors trim as normal? As for the props pitch, is there a way to measure it so i can see what it is?
WillyBWright
Re: hydrofoil for
Re: hydrofoil for
Props usually have their dimensions or a part number stamped or embossed somewhere on them. Tabs can allow you to trim the motor higher (a bit) which could give you more speed. They can also wipe-out any porpoising problems.
Re: hydrofoil for
Re: hydrofoil for
get a manual and start trouble shooting. it use to run 50mph, it still should. either the engine is sick or the boat is sick(wet foam).
Dead Eye
Re: hydrofoil for
Re: hydrofoil for
Put one on ny last boat. 18ft wellcraft W150/ MERC. Got up on plane better and stayed on plane at lower rpms. I liked what it did for me. May have lost some? at top end but saved fuel on plane at lower speeds. Wasn't' pushing water.
Dead Eye
phatmanmike
Re: hydrofoil for
Re: hydrofoil for
you are not listening to anybodys advice.
stop thinking about tabs or fins, and find out what is wrong with your motor and or boat first.
if it used to go 50, it still will if all is good.
Re: hydrofoil for
Re: hydrofoil for
check your plugs, and spark, compression, you may need some carb attention, linc n sinc. the engine has to be healthy first. then if you still have problems getting on plane go to the smart tabs. i personally think foils are the ugliest thing you can put on a boat. it also yells i have a bad performing boat, and i'm too cheap to fix it right.
