Re: RODBOLT!!!!! I NEED YOUR HELP 1999 4 STROKE YAMAHA 80hp
trust me, ring free was NOT your problem.
I have seen 2OZ per gallon treatments run for 20 gallons with no problems.
guy misread the label.
we normally shock treat by running 6 gallons of 87 octane mixed with 16 oz ringfree at normal cruise speeds.
its actually reccomended for certain engine conditions.
if you have carbon in the injector screen it came from the brushes on the electric pump motor inside the VST. its a blow through type pump and why VST filter cleaning is periodic maint.
most likly you just got some trash in the system, happens even to the best.
my suggestion is keep the fuel system as clean as possible, we are even starting to remove fuel senders and physically clean tank bottoms of water now.most likly this ride did not turn over fuel very much and with an addition of a different fuel blend on an old fuel blend you got the gas nasties.
looks kinda like gray snot and will pass right through a water seperato,VST but not an injector screen.
seen it a bunch this summer.
our current fuel blend sucks but I am making a killing off it, but its shut my F150 down once and blew up my 175 ETEC.
dunno what its going to do to my 27' albermarle with a pair of 05 MPI 5.7 volvo's.
havent added fuel to it since spring and still have about 150 gallons onboard.
good luck, keep the fuel fresh,turn it over at least every 3 months and pray.
its the best I can reccomend now until we get this waste of money and good corn likker overwith.
