Hello, I have a '86 Correct Craft with a 351w. I developed a hard/no start when the engine is warm. If I shut it down and immediately start it it will run. If I wait a minute or so it will crank for ever but it will start with ether. Either way it runs great. It has a new holley that ran great last year, Pertronix ignition, new ignition switch and solinoid.
The interesting thing is that I noticed that when it is cranking (and not starting) I can occasionally let off the key and it will either start or sputter once. I took it out on the water and retarded the timing till it started to ping. After this it started great, no problems but the timing is at around -18 degrees. My thinking is that I don't have a strong enough spark and to high of compression when the timing is right and a low enough compression for it to fire then the timing is retarded. It has the stock (old) coil and ballist resistor. Either timing setting the engine runs fine. any input is appreciated. thanks
