hullofalottatrouble
Thread starter- Joined
- Jul 16, 2005
- 306
Dropped in a reman merc 260.. everything bolted into place.
got it started.. started and ran strong at around 900 rpm.. vacuum gauge read dead solid at 15.. little low but dead solid..
when i throttle back all the way it just died.. didnt run rough just died.. so figured it was an idle needle/screw adjustment.. or perhaps a throttle cable adjustment needed.. wasn't terribly concerned.. but had a therm housing leak so shut it down until got new gasket
all cyl are 150 dead on with compression test..
also wanted to tighten down the dist and swap out carb gasket in case slight vacuum leak there..
also pulled all plugs and cranked engine over to check for water .. fuel etc in cyl.. all good..
swapped out carb gasket and after getting carb back on - see other post - i bent the right idle mix needle on my rochester qjet...
i swapped the needle out with one i had in my old carb.. cleaned it off put it in..
put new gasket in therm.. put all plugs back in..
and started engine.. it ran terrible.. vacuum fluctuation from like 10-15.. sounded like cyl werent firing.. had to keep it at like 1200rpm to stay running.. checked to see if timing was way way off.. got it set dead on.. didnt help..
adjust left carb needle.. it had an impact on engine.. tried to adjust right carb needle.. it didnt do much..
the noticed smoke/steam rising from bottom of 2,4,6,8 exhaust manifold.. shut down engine.. manifold was super hot.. also had steam/vapor out of top of carb.. i checked manifoldd/riser before bolting on to reman and they were clear and thick walls.. new gaskets on them. and did not have overheat problems with them at end of last year.. also did not have overheat problem first time started reman engine before needle was bent...
didnt mess with it anymore.. comp test on 2,4,6,8 after all this was 150 dead on..
i am hoping all this is related to my bent carb needle and damage to seat..
but just wanted to check to see if doing this kinda of potential carb damage alone would result in such a terrible running condition.. i am guessing yes..
but before i went full steam ahead on trying fix carb wanted to make sure there wasnt something else i should look into..
thanks
thanks
