Took the boat out this weekend & noticed a vibration when in low rpms' going forward. I just changed the lower unit oil & found the normal metal fuzz along with very small & thin pieces of metal (fall apart in your fingers). In addition, I recently removed the lower unit to change the water pump. Could this be a shifting problem or worse? When running on the trailer in gear at low RPMs' it knocks & bumps. Reverse seems to be ok.. I removed the cowling & in forward gear looks like the pin is moving all the way forward. Thanks!
