forward shift goes backwards
hearly
Hi, i just had a new aplha one gen one aftermarket stern drive installed and when I shift the control forward the boat goes backwards adn back wards goes forward.
What goen wrong, who can i fix it and will i do damage driving it like that.
cheers,8)
DHPMARINE
Re: forward shift goes backwards
Sounds like the drive is wrong.Maybe counter-rotating and you needed regular.
Since you just had it installed,tell the shop they screwed up and ordered the wrong one.
DHP
bamadave
Who's aftermarket drive is it? Just curious.
Bt Doctur
My bet is a "counterrotating unit" got installed by accident.
hearly
not convinced as a counter rotation drive, surely that would have to be marked on the drive clearly.
Oh the drive came from SEI, cheap and fast delivery.
Boatin Bob
I've seen both OMC and Mercruiser counter rotating drives (on boats with twins at the time) and except for the different props there was no way you could tell.
hearly
thanks Bob, i will check that out later today, just taught i might be a cable issue,
is it OK to drive it, or should I just change it ASAP
bamadave
I was under the impression that SEI didn't sell the counter-rotating drives, I talked to Erica at SEI yesterday, but did not inquire about the counter-rotating drives. She said they have 12000 units in the field with a 3% failure rate. Warranty 1 year. Web site is
WWW.Sterndrive.CC NOT A PLUG, info only. I have not used them, but will try them soon.
Bt Doctur
If all you did was change a unit and now it operates in reverse I`d bet dinner it`s a C/R unit
hearly
we also had the control cable changed, is there such a thing as CR cables or are the all the same.
Cheers,
Don S
Cheers,
And now The Rest of the Story
How could the cable be counter rotating? ? ? ? ? ? Look at how they are made.
It's hooked up on the wrong side of the control
hearly
thanks for the feedback,
is it Ok o drive or should bot operate till its fixed??
Blk-n-Blu
I may be mistaken but i seem to remember that when changing the lower unit the shift control should be put into the forward position, When joining the two halves back up there is a flat linkage that needs to be aligned into a slot in the lower. If the lingage or the slot are reversed you can wind up with a backward shifter. I would not operate the boat in that condition. Take it back and get it done right. just my $0.02 good luck8)
Don S
You can't put it back together that way
Scaaty
Get the damn thing in a shop before ya kill someome. You come up to a dock, nail reverse thinking its reverse, only now its foward, ya lauch the boat over the dock killing some kid......are ya stupid or what?. Sorry, but some people just have no clue as to just no F'ing clue as to what stupid is. Hey, why don't ya just sit facing the rear...solve all yer problems.
seahorse5
cheers,8)
If it is not a counter rotating unit, perhaps someone installed a left hand prop.
Do you have twin engines and replaced the port side unit with a regular rotation drive?
Reel Poor
sker crunch
Here is a link from SEI's bb of a guy inquiring about a counter rotating drive.SEI bb link
