Fall Steelhead fishing in Idaho
KRS
Banned
Going with Dad this year, he's an amateur steelhead fisherman.
He says the average number of hours per fish is 13 !!!
I'm hoping to up my odds with some help and ideas from the forum members.
I believe it's the "East" or "North" Fork (of a river in Idaho 8) ), it'll be 3rd week in October, and it's Steelhead.
Unload your precious knowledge upon this poor wretch.
KRS
Banned
Re: River Steelhead Fishing, Fall in Idaho
anyone ever fished the salmon river, just west of North Fork?
KRS
Banned
Re: Fall Steelhead fishing in Idaho
^bump^
Anyone have any input, ideas, suggestions, pictures, stories, methods, etc.?
Thank you.
KRS
Banned
no one?
bbright
North Fork Clearwater river. it begins at the hatchery and ends at the dam. steelhead fishing picks up in oct. but like most river fishing it depends on the year and water temp. the colder the better. I usually fish between lewiston and orofino. later in the year, the north fork produces a lot of big trout and is next door to the largest steelhead hatchery in the world. i think the most productive technique is slip bobber and jig. last year it was only 5 hours per fish and hasn't been that good since 2001 when i first started. once you catch one, i will be addicted. it's only a 3 hour drive from where i live and well worth it. if anyone would like more info let me know
Bass-A-Holic
here in michigan i use a bottom bouncer w/ a spawn sac but i dont know what u do in Idaho.
KRS
Banned
I was skunked. Fished the three-day license very hard and didn't get anything.
We used flies with a corky in front.... didn't see any of the slip bobber and jig methods.
Thanks for the responses!
Bass-A-Holic
Well, I think they are probobly one the the hardest fish to catch, so don't feel to bad. You probobly didn't do anything majorly wrong, the fish are just to picky about little things. I normally have a had time catching them, unless i fish with my neighbor who catches them like panfish.
KRS
Banned
It's hard to justify a week long trip when you don't catch fish :(
Maybe in a few years I'll go back... I'm just trying to make my way to Lake Powell for stipers this year or next.
KRS
Bass-A-Holic
KRS
O, i see, well your right then, jk, like i said they are one of the hardest fist to catch, and you may have not done anything that was majorly wrong, those fish are down right picky. Good luck next time though!
ctak
What river did you fish? Was it the Clearwater or the Salmon. I've fished over there the last year or so and use the same set up on both. It's a corky and pencil lead set up w/ raw shrimp. I usually use an orange corky w/ a little yarn. You want enough lead to bump the bottom. I assume you are bank fishing. I'm sorry that I didn't see your post earlier... or I would have sent you some. Anyway that week in October is a great week, but you have to be at the right place on the rivers. Don't give up it's a great fishery and once you catch one your hooked!
brianvolt7
For anyone that may stumble across this. Steelhead fishing is truly the most challenging of any fishing that I have ever encountered. Polarized glasses will be your best friend when steelhead fishing. If you can spot them, you have a good chance of hook-up. Remember, if you can see them they can see you.
My favorite technique starting from the bottom. Use a Gamakatsu hook, absolutely the sharpest hook you can find is what you want. Small hooks work great, my most productive #4 and #2, no larger. Tie it with an egg loop, not to use eggs but for the strength. Depending on depth and clarity, the heaviest leader should be a 10#, preferably a 6-8# if you can safely let them run. Make it at least 6 feet. Now slide a corkey, pink pearl or black, the smallest that you can use with the current to keep it on the bottom but off the rocks and weeds. Tie a double solid eye swivel to the leader. Run a slinky up your main line on a standard swivel. Main line should be 10-12# for the smaller summer run, 15# for the fat winter run fish. Now a small bead to keep the slinky from catching on the double solid eye swivel (DSE). Tie the DSE swivel onto the main line. Adjust your slinky weight according to the current. Run a small piece of yarn through the corkey to keep it from moving up the line, this catches in the fishes teethe and gives you a couple of extra seconds to set the hook. Cast and drift, pole tip up, they will just mouth it, your line will stop like it is dragging on the bottom, but after casting a pattern over 10 minutes you should know if this stop is a regular occurrence in your pattern or not. If not, swing that pole like a baseball bat in reverse. There mouths are hard and no trout set will work. There will be no second chances at this fish. Now just HOLD ON!!!!! One other thing that steelhead have a hard time resisting is three or four full night crawlers dangling from a #2 razor sharp hook floated just above bottom level under a clear bobber. GOOD FISHING!!!!
fuzzeywiggler
I did a rig like this very successfully this spring, (proof is in the dp).
we were drift fishing with these rigs.
You get a 3 way connector, on the top is your line, on the bottom about 1-2feet down is a pencil weight and off the back about 6 feet you have spawn with a tiny hook buried in it. chartruse and natural salmon eggs worked really well.
Fuzzey
rolmops
In the creeks off Lake Ontario we use either small black woolly buggers with silver eyes or salmon eggsacks We allow them to naturally float with just a bit of sinker to keep them down.Let it run down stream through a hole or past a rock and chances are that you will get slammed almost as hard as a salmon would slam you.But these are Great Lakes steel head mostly in the 10 to 15 pound range,so that may be very different from hatchery steelhead.Also around here in fall we usually catch them at a rate of 3 to 5 per hour.
Around here we call steelhead "bug eaters on steroids".
brianvolt7
Good advice, I?ll try it. Last good season I had, year before last, before moving to a new state was 22 Chinook, biggest 35#, 3 Silvers, biggest 9# and 11 Steelhead. The runs aren?t what they used to be though. Silvers and wild fish are always released and I smoke or bbq the fin clipped hatchery fish. all caught on pearl or black corkeys drifted.
