trim fluid question
hurricane
My trim fluid is a bit low. I went to fill it and found the fluid to be gold and not red like i expected. The fluid looks like hydralic steering fluid. Is this fluid ok? The trim system works OK. I know other engines use this type of fluid. The manual says to use ATF. Should I try to change it? If so is there a way to drain the fluid?
rodbolt
Re: trim fluid question
you can use ATF dexron III or the factory trim fluid, the ATF is red the trim fluid is clear/gold looking. either one will work.
hurricane
thanks. I thought it would be alright. Rodbolt you are a great help.
