Johnson 2 hp air or water cooled? Rich/lean settings?
Rich
I just purchased a Johnson 2 hp 2 cyc. built in 1972 (2R72 ser E3533357. I believe this is water cooled since there are no cooling fins on the engine,but I did not see a discharge stream coming from the engine. Can anyone tell me if this is water cooled and if so, where to look for the discharge stream to be sure it is working?? (Also appears to be an impeller inlet above the prop) Also be interested in how to change the oil in the lower end, and how to adjust the slow/fast rich/lean knobs as well. Thanks!
Re: Johnson 2 hp air or water cooled? Rich/lean settings?
it's water cooled, and my manual is very unclear as to how to change impeller. may be on of those you have to pull the power head. looks like the is a single screw on the side of the foot to drain and fill, ther are usually 2 drain/fill and vent. email me and tell the you need idle adj.
tashasdaddy@comcast.net
JB
Impeller is quite easy because there is no shifting mechanism to disconnect or reconnect. Just unbolt the foot and off she comes. That series used two different impellers; be sure to get the right one.
Drain and fill gearcase through the one plug. Be sure to use a fresh gasket.
No telltale. Water exits through the exhaust ports low on the back of the leg.
Great little engine.
Xcusme
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
thanks Xme
Rich
Thanks to everyone!!!!!!!!! Worked on the engine last night and she's purring like a kitten......... Time to reduce the Utah trout population. thx again
Rich
another happy ending. let us know how it runs.
supercoolbabe
My 1972 2hp likes a lean setting when running fast and a rich setting when idling. The depth of the foot affects the way the motor runs more than any other motor I have ever used. The exhaust comes out of the back of the motor just above the foot. I feel for the water spitting out of it regularly. The impeller is easy to replace, just be careful with the o-ring. The lower gear lube has one screw. I turn my motor sideways to empty. To make sure it refills all of the way I clear the hole to allow air bubbles to escape.
Johnshan1
I am having trouble with my engine, a 1981 model.
I have cleaned the carb.
I cant get past 1/2 throttle (The start position) without it stumbling and dying out. Idle speed seems great. Should I tear the carb apart again or keep messing with the adjustments?
River Boy
Yep. I bought a new 76 2hp Evinrude. It was all I could afford at the time or I'd have bought a 4. Seems like $280. Had to be constantly fiddling with the high and low speed adjustments. Even a few degrees of water temperature would be enough for a little tweaking. Like a Piper Cub I guess. Also, that motor was very very easy on gas. I wore it and a Herters square stern canoe out on Ozarks gravel rivers. Not once did I ever break a shear pin. I went through 3 or 4 props though the years I had it. I'd just grind them down till I had to get a new one but never busted a pin. Wish I had it back for a wall hanger.
Johnshan1
I find this engine interesting as well.
My great uncle used it on his canoe, and when he passed on 6 years ago it was given to me. It was siezed from lack of use, I took it apart and couldnt find anything wrong, put it back together and it runs great other then the problem posted above.
I took that engine down to every single nut and bolt, sanded and painted everything. It looks brand new again- minus the missing decals.
