2001 ESCAPE rear brake issues RESOLVED
KaGee
Why won't they self-adjust??
My emergency brake lever pulls all the way up, with no brake!
Linings were just replaced last fall and emergency just strted to not work. Not a good thing with a 3000lb boat at the ramp.
ob
Re: 2001 ESCAPE rear brake issues
Not sure what kind of rear brake setup is on the rear of your Escape.If they are disc brakes,some have an integrated drum for the emergency brake shoes.May just need cable adjustment.
Reel Poor
KaGee those are drum brakes so it going to require visual inspection. How does the pedal feel,,,,Low or high and tight with very little travel when pressed. Check self adjusters, e-brake cables, and e-brake lever connection to shoes (inside the drum).
KaGee
Ya, I was afraid I was going to have to pull the drums again. .)
Bob_VT
I am just guessing but, most drum brakes adjust only when you stop hard in REVERSE. If you have to pull the drums why not relace the shoes with high qaulity shoes (regardless of the condition of the old ones) considering you tow with it. Your going to have to pull the drums anyway and the shoes are cheap.
KaGee
Bob,
I read somewhere in the stuff I have that the adjusters are different on this one. The going in reverse is what I am used to. Went out to a parking lot, threw it in reverse and backed braked hard just for the halibut about a dozen times. I think the gawkers thought I was crazy. But, still no difference. Must be a hardware problem on one side or the other. The shoes were new last fall.
Any rate, I'm going to look at it in the A.M..
KaGee
Re: 2001 ESCAPE rear brake issues: SOLVED!
FYI, the rear brakes adust via useage of the parking brake. Something new I guess.
I had two problems, the adjuster on one side was stuck and I had a bad parking brake cable. All other hardware is OK. New cable going in this morning, brother what a pain that is!
D
DJ
Guest
Re: 2001 ESCAPE rear brake issues RESOLVED
Yes, the rear brakes adjust by use of the parking brake. It's been that way, for a while.
Reel Poor
Cool,,,,,,No more circleing the block,,,,,Now you can stop when you get there. ???
KaGee
Or pulling my truck out of the drink, trying to launch! I didn't need to be another SHT!
